Cognew issues
hey, i'm having trouble launching cogs. for example, when i do this:
the chip locks up and the motors never start but this:
makes it work smooth as butter. i shouldn't be running out of cogs, i've run through my code and i should have at least two left... i can post all of my objects if you'd like.
~~Brian
OBJ
motor[noparse][[/noparse] 2] : "SetMotor"
bs2 : "BS2_Functions"
encoder : "Encoder"
VAR
' Motor 1
BYTE speed[noparse][[/noparse] 4]
LONG encoderstack, stack[noparse][[/noparse] 20]
pub encodertest
bs2.start(31,30)
motor[noparse][[/noparse] right].init(_esc1PwmPin, _esc1DirPin, _esc1Freq, 0) ' initialize SetMotor.spin 0
motor[noparse][[/noparse] left].init(_esc2PwmPin, _esc2DirPin, _esc2Freq, 1) ' initialize SetMotor.spin 1
cognew(encoder.start(0,2,0,@encoderstack), @stack)
motor[noparse][[/noparse] right].setmotor(50, 1, 1) ' slowest speeds that motors can start at (lower speeds can be
motor[noparse][[/noparse] left].setmotor(50, 1, 1) ' achieved by lowering speed once moving)
repeat
bs2.debug_str(string(cr, cr, "Right: "))
bs2.debug_dec(encoderstack)
'bs2.debug_char(13)
bs2.debug_str(string(cr, cr, "_____________"))
waitcnt (cnt + 80_000_000)
OBJ
encoder : "Encoder"
VAR
' Motor 1
pub encodertest
bs2.start(31,30)
'cognew(encoder.start(0,2,0,@encoderstack), @stack)
repeat
'bs2.debug_char(13)
~~Brian
For cognew to work as you intend, you need to launch code that is only within the object that you are executing the cognew instruction from.
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
EDIT: Worked like a charm. They should have the compiler flag that as an error, if that's possible... oh well. thanks!
~~Brian
Post Edited (Litefire) : 3/25/2007 2:36:59 AM GMT
