"Serial Relay Output / Opto Input" noob question
jefm
I have a project that need to switch 120vac loads on/off. I'd love to make a PCB for it with relays transistors and all that. But to get started realistically I might just buy a couple of these:
http://cgi.ebay.com/Serial-Relay-Output-Opto-Input-Basic-Stamp-PICAXE_W0QQitemZ140099191163QQcategoryZ4661QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Looks cool and it's ready to go. Question is can I run a few of these on a BS2? I'm pretty sure I know the answer but I haven't done much serial stuff yet and want to be sure before buying!
thanks,
jefm
thanks,
jefm
You could connect more than one to a Stamp, each to its own set of I/O pins. The Stamp could only talk to one at a time, but these maintain their settings until commanded otherwise. You could only listen to one at a time, but they repeat their status messages once a second, so you'd only have to wait (at a SERIN) for about a second to get a fresh message.
