Help in using BS1 and MAX7219 LED Driver to make a Timer
I'm new to this forum. I have worked with BS2 mostly, but I·am working with a BS1 for the first time.·I am trying to·make a LED timer using the MAX7219 display·driver chip. The sample program that comes with the documentation just counts from 0-65535. I would like the program to respect the minutes and seconds. I would also like to know how to turn on the decimal point for a given number.·Any help with would be greatly appreciated. Thanks, Aanon
I don’t believe there is a more detailed or specific example of what you’re trying to do. Perhaps you could look at a BS2 example that does do this and see how you might convert it using the example BS1 code you have. The following link is to a BS2 Project which does make use of the decimal points for the MAX7219 as well as displaying hours, minutes and seconds. I hope this helps. Take care.
http://forums.parallax.com/showthread.php?p=552892
