Propeller's Daughter
Hi guys,
I was wondering if it would make sense for the experienced guys to get together and come up with a standarized form factor for a daughter card...
What inspires this question is the following:
1. I think I've said it before... but I'm a retired eye doctor and I used to keep track of all the ways people found to blind themselves. Soldering irons wasn't one of them, and I don't want to be the first.
2. Everytime I see a neat circuit on this forum together with an historic little spin program... I want it immediately, but I don't want to hurt myself.
I think there could be a cottage industry for the right chip minded group of co-conspirators.
What do you say?
Rich
What do you say?
Rich
Nothing against daughterboards, but soldering irons aren't that bad. I kind of enjoy using them, actually. As a doc, I've also seen lots of (dumb) ways to break, burn, crush and slice one's self. But besides occasionally picking up the wrong end of the iron, it's pretty hard to hurt yourself with one.
Jim C
1) Get a solderless breadboard ... like the one used in the Propeller Education Kit. With few exceptions (like the Propeller A/D conversion bit) it works fine. Parallax sells them separately, even sells precut and stripped wires.
2) Make up a soldering station with ventilation if you want and use goggles or safety glasses
It's really hard to come up with anything standardized when the uses are so varied.
2) Do as Mike says, you can even (with a little soldering) make one of these.
http://forums.parallax.com/showthread.php?p=621981
Graham
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
Martin-- thanks for mentioning work habits. It is ALL a matter of routine... but you have to do enough to make it a routine. After not playing with my dremel for a while... I found myself putting it down, without turning it off, while my attention was focused on the piece I was working.
Graham said "Be a man[noparse]:)[/noparse]" I'm too old... and one divorce was enough[noparse]:)[/noparse]
On the serious side... what I really want is a Propeller on one board and just about everything else talking to it across an adapter that doesn't fail too often AND handles noise like a deaf mute at a PETA convention. I have a growing list of reasons why I think this is a good idea.
Rich
A current pic of mine is attached..
Oldbit
My problem is that I want everything... the last time I looked at Parallax's product sheet, I could find independent reasons for wanting all of it.
And I want everything... right now. Which is not exactly the way a person should live his life. You know?
I've resolved myself to solder... I don't see why the world won't just put sockets where I want them... but apparently that is the case.
Tonight, I'm fixing my daughter's IPod adapter, which was apparently put together during a clip shortage in Taiwan.
I'm pushing the concept of a daughter card right now because I have "ulterior" motives... but I don't exactly know how to explain them. It will all be public domain or I won't waste my time.
By the way, I have a question for you... and Graham.
Since it is a fact that little pins on microprocessors all have L and C disease... and since we know that A/D can't always happen right at the well head... wouldn't it make sense to somehow buffer all of the lines?... Isolate them from the system noise right out of the box?
Oldbutt (Rich)
Can you post a closeup of your breadboard - I'm interested on how you interfaced the Wico joystick
Oldbit
You must have a very quiet dremel.
Graham
