lookup table for BS2
dbj
· Could you do a lookup table that each time it receives a command to lookup a valid number it will use that number until the next number is received. Then the first number becomes invalid and the second number is used until the next code is entered, and when the last number in the lookup table is used it returns too the·first number in the table.
···················································· Thanks
The "LOOKUP" command sounds good for this.
