split a rs-232 signal
Hi!
I have a·OBD scanner·witch sends seriell strings to my stamp on port 3,4 (3 tx and 4 rx).
Now i want to split this signal so i can see the data on the attached lcd and on the computer where i use a "real" program.
I use a BS2.
Anybody got ideas or schematics?
Robban
I use a BS2.
Robban
Can you explain what you mean by "split"?
Bruce Bates
The problem is, any 'handshaking' (sending TO the OBD) must be done by only one of the devices -- I assume the BS2 will do this, or your "real" program can do this, but not both.
