TTL to RS-232
Hello,
in my microcontroller i have serial connection port(RS-232) with 3 wire and 5 wire...
but printer inkjetki has TTL connection. So how could i convert TTL to RS-232?
thanx
thanx
I'd be surprised if your Inkjet printer used TTL signalling. Perhaps it uses TTL Parallel. Perhaps it uses RS-232 +- 10 volt signalling. And probably your Microcontroller does RS-232 signalling at TTL levels.
A MAX-232 chip does TTL on one side, +-10 volts on the other side. So that's the simple answer to your question. But as I say, you really need to nail down how many pins, and what voltage levels, each side uses.
