I may have missed it
I am building a Boe-Bot version 2.· I may have missed it in the manuel, but can I use NMH rechargeable Batteries?
I have been using Eveready alkalines to the good, but would like to set up a small solar panel to keep the batteries fresh.
![confused.gif](http://forums.parallax.com/images/smilies/confused.gif)
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
Unless you get some cells that are able to produce a charge large enough to actually cap off batteries your not going to accomplish anything but extra parts.
There are "Trickle Chargers" on the market that are designed to charge car batteries via a low but continous charge from a solar cell, you may want to check into those. Anything that is inexpensive will more then likely require trickle charging.
One place to check out is the North American Solar Challenge at http://nasc2005.americansolarchallenge.org/index.html
There is a page of links that may be helpful and there are also pages explaining how solar cars run. The general overviews may give you concepts to follow or directions to head towards.
