hz reader and switching — Parallax Forums
prochipsprochips Posts: 6
edited 2007-03-24 03:37 in BASIC Stamp
hello
I·trying to·write the code for bs2 oem·,· for reading hz of 5v square wave and later trigger relay if the Freq is > 120hz
but dosent work
·thanks
·wilson
Post Edited (prochips) : 3/21/2007 4:44:12 AM GMT
538 x 382 - 9K
  • stamptrolstamptrol Posts: 1,731
    edited 2007-03-21 12:09
    Wilson,
    Everything looks OK.
    Are you sure the the square wave is actually swinging the stamp pin 15 from 0 to 5v? Also, is the negative from the square wave source tied to the stamp's negative?
    You can reduce the 10K resistor down to 100 ohms or so when inputing a ttl signal.
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
    edited 2007-03-21 12:57
    I see no ground input indicated -- have you connected a ground as well as the desired signal?
    edited 2007-03-21 15:06
    How many pulses per revolution does your motor produce? If it's one — not four — you need to compute RPM as follows:
    RPM = Pulses * 120
    The same applies to the frequency. Since you're counting for 1/2 second, the frequency you want to check will equal pulses * 2, not pulses.
    And finally, in your code, when the value being checked equals 100, the state of the LED doesn't change. Is that what you intended?
  • prochipsprochips Posts: 6
    ok ,I need conect ground to input signal
