Debugger Window Problem
I don't use the debugger much, but it is very helpful when I do. When I drag a debugger window off the screen, it disappears and I can't get it back. This has happened with the main control window. I have to use the shortcuts whenever·I use the debugger. I have already tried uninstalling/reinstalling with no luck. I'm not sure what to do.
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Specifically, go to HKEY_CURRENT_USER\Software\ParallaxInc\SX-Key\2.0 in regedit and delete the entire entry "Debug Window". The editor will rebuild the key on the next editor launch. I have to do this for many of the editor's windows as they randomly resize into tiny boxes that aren't usable. I wish there was a fix (as in don't even bother saving window sizes for windows that can't be resized, etc).
Harrison
How are you able to drag a window offscreen so that it disappears? On every computer I won, the mouse won't go past the edge of the screen. Because of this, there's no possible way to drag a window so far offscreen that it "disappears."
PeterM
The next time the window resizes on you, take a screenshot and post it so I can see what it looks like.
PeterM
PJ, I just drag it to the bottom of the screen and it disappears.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
You could delete the entire registry section for sx-key, and reinstall. That should fix all of your odd setting problems. Be careful though, make sure you don't delete anything outside of the SX-Key section or else bad things can happen.
I don't understand how dragging the window to the bottom of the screen makes it "disappear". You mean that you can see it while dragging, but as soon as you let go of the mouse buitton the window vanishes?
PeterM
