How do i measure the frequency of a signal running round a wire loop.
Hi, i have built a mobile platform with two powered wheels at the front and a caster type wheel at the back so that it will travel around. There are whiskers on the front so that when it hits an obsticle it will reverse, turn and then go forward again. I now want to contain it in an area without walls.
My mother has a Mowbot which picks up a sinusoidal signal from a burried wire in the lawn and I thought that I could find out the frequency her robot uses so that I could run my robot inside her perimiter. This way I can consentrate on building a receiver and get it working without having to build a transmitter at the same time.
My Question :-
How do i find out what the frequency of the signal running round her lawn wire is ?
Any help would be apresiated.
My Question :-
Frequency Counter· Nikkai RP80
Coil· 5 turns of 2cm diameter
Orientation·· 300Mhz range···· 3GHz range
in line········· 17Mhz···············331Mhz
90%··········· 25Mhz·············· 300Mhz
I then turned OFF the power to the Mowbot system and the signals were a couple of Mhz lower on the 300Mhz range and 20Mhz lower on the 3Ghz setting.
but sitting at my·computer here,·i have turned it on and it reads
18MHz and 350Mhz
I am confused as to what the readings mean and wonder if all i picked up was background readings.
Any suggestions
Richard
Post Edited (Billericay-Boy) : 3/22/2007 6:16:06 PM GMT
Is there a lower range you could try? Maybe you could locate the generator for the Mowbot signal somewhere where it's dry and try measuring there?
Any idea what sort of range ? i have seen plans for 50Khz to 70Khz and that is far lower than this is counter is reading.
The range should be on the order of a foot or two. You don't want it to be so far that it would confuse the Mowbot, yet you want the wire to be able to be buried.
I can believe 50KHz to 70KHz.
I will post my results when i get one.
Any offers of a loan machine - Billericay - Essex - UK.
Richard
9999Hz LED DIGITAL frequency panel meter with 4-DIGIT RED led display
Display type :·· 4 Digits, Red LED Display
Operating Voltage :·· 5V DC / 500mA
Frequency Range :·· 0 ~ 9999Hz
Accuracy :·· ±1Hz·
Peak Voltage :·· <16V·
Input Waveform :·· Regular Periodic Waves
Installation Type :·· Flush Mounting
Dimensions :·· 79mm × 35mm × 27mm
so i should have some more readings next week.
for the help.
Did I miss something?
Mike writes :
I don't understand what this foot or two etc. has to do the frequency of the signal.
Please Mike, can you explain.
Ed
Higher frequencies would tend to be absorbed more by moist earth and would not be radiated well or evenly by wires on the order of several wavelengths. The lower frequencies would tend to be radiated more uniformly by a long wire and not be absorbed much by earth overlying the wire. There would also be a significant amount of inductive coupling to a small loop which would help with directionality (sensitive to small changes in direction and distance).
thank you for the explanation about behaviour at high / low frequencies but you lost me when you write that lower frequencies radiate
more uniformly by a long wire. Does this mean that EM radiation is depending on frequency (golf length) and wire length ? Makes
sense since similar ideas are behind antennas but .. the golf length of a 50KHz signal is 6000 meters and I have difficulty to
relate this length with the length of the wire for which this Mowbot is working fine.
Here's a starting point for information: en.wikipedia.org/wiki/Antenna_(radio)
thank you. That makes sense to me.
Regards, Ed
the reading was fluctuating between 73Hz and 80Hz with the aerial in line with the wire and up to 83Hz with the aerial at 90 degrees to the wire.
Could there be 2 signals going down the wire one in the low 70's and one up at 80Hz ?
I suppose i will have to build a receiver that i can tune into the frequency between 70 & 80Hz.
Any suggestions or offers of help with PCBs would be accepted - i have plans from a guy's website (URL=http://www.betuwe.net/~mowbot/UDO5recvRcv.PDF] who has made one already.
