Interesting LED driver, 4 programmable PWM pins via I2C(motor control) — Parallax Forums
T ChapT Chap Posts: 4,249
edited 2007-03-20 19:00 in General Discussion
www.standardics.nxp.com/products/pca/pdf/pca9633.pdf
I was looking for a way to individually dim some LEDs via I2C, and ran across this part. Since it is simply 4 I2C programmable PWM pins, it could be used just as well for 4 PWM motor speed controls.
Maybe somebody might be inspired by it. Digi has them for around 1.60
said...
The PCA9633 is an I2C-bus controlled 4-bit LED driver optimized for
Red/Green/Blue/Amber (RGBA) color mixing applications. Each LED output has its own
8-bit resolution (256 steps) fixed frequency Individual PWM controller that operates at
97 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set
to a specific brightness value. A fifth 8-bit resolution (256 steps) Group PWM controller
has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once
every 10.73 seconds with a duty cycle that is adjustable from 0 % to 99.6 % that is used to
either dim or blink all LEDs with the same value.
Post Edited (originator) : 3/20/2007 5:33:13 PM GMT
  • IbsenIbsen Posts: 68
    Very cool !!!
    Ibsen
    " It's nice to be important, but
    ·· more important to be nice... "
