Purchasing wheels for a robot
I figure, many (if not most) of the people on this forum have built robots at one time or another. I need to get a set of large diameter but thin rubber tires for my robot. the wheels i have now just don't have enough traction.
Does anyone here have any places to look for such an item? Just thought i'd ask.
~~Brian
~~Brian
Glad to help,
Marty
~~Brian
Are the stairs carpeted or hard surface ?
I ask because I can cut out wheels from 1/16" pcb material (no copper) on my LPKF mill.
Pretty much anything you can draw I could cut.
If the stairs are carpeted, maybe some wheels with "teeth" would work good.
Bean.
"Educate your children to self-control, to the habit of holding passion and prejudice and evil tendencies subject to an upright and reasoning will, and you have done much to abolish misery from their future and crimes from society"
Benjamin Franklin
Coming soon! Propeller based OSD module www.hittconsulting.com
i found a perfect set at lynxmotion, 3.5in diameter 1.75 in wide, but the hubs on these are 6mm and i have a 5mm motor shaft. any ideas if these might be compatible anyway? i would need them soon, competition's on april 13/14, so if these can somehow be compatible... it'd be great. i'm hopeful but not banking on it.
~~Brian
would anyone know where to find a 6->5mm bore reducer? or any part that allows a 5mm shaft to mate with a 6mm hole?
Parallax Forums - If you're ready to learn, we're ready to help.
i'll get some and try it out soon. thanks!
~~Brian
