USB to 232 BS2 communication problem
joshuazvi
I have successfully worked with my BS2 and BOE on my old computer for quite some time and am very happy with it. I recently tried to use it with my laptop and am having problems. I bought a USB to Serial 232 from parallax and downloaded the driver etc. the editor recognizes the com port but not the stamp. I tried in BM options moving the latency down to 1 as suggested with online troubleshooting and it didnt help. Not sure what to do. please help, very excited about getting back into the BS2.
-Joshua
-Joshua
The FTDI-based USB converter does need it's own drivers loaded before the USB is plugged in. Otherwise, a 'generic' USB to serial driver is loaded -- which does not support the FTDI properly.
unfortunately it didnt work. i unplugged the adapter and reinstalled the driver restarted and plugged in. my computer recognizes the usb adapter but when i go into the basic stamp program it doesnt recognize the stamp which i have plugged into the adapter.
any other ideas????????
thanks again
Are you using a BOE?
not sure what a 'straight through' cable is
It sounds like you're connecting directly to the BOE boards DB-9 connector with the USB adapter, which should work.
thanks for all the help!!!
