Component Advice
I'd appreciate some advice regarding the following:
1.· I want to trigger a solenoid·(that has an·independent power supply) with a basic stamp 2·on a BOE.· The solenoid takes 12V 130 watts.· I'm looking for a low cost component that I can open/close with the stamp to complete the power supply circuit for the solenoid.
2.· I have multiple solenoids that I would like to power with one power supply.· I would like to find some type of· off the self IC with screw down connectors that will take a single power input and provide multiple power outputs at the other end (also screw down connectors).· This is the IC equivalent a multi outlet power·strip.
Thanks.
Thanks.
2) If your solenoids are all similar in power requirements, you will need a quality power supply much more than just an IC. Have a look at Jameco's on-line catalog. They have a wide selection of power supplies with power ratings up to 600 watts.
3) You're talking about a lot of current here. Switching noise and ground loops are going to be a problem. If you don't have experience in designing systems with multiples of 10 amps of current being switched into inductive loads (the solenoids), you should get professional help.
4) Jameco (and others) also have some small high-current relays that can help provide the isolation you may need. There are one or two relays in their catalog with 15A contact ratings that could control your solenoid, run off a separate 12V supply, and only need about 30ma of coil current, easily switched by a cheap switching transistor. The "What's a Microcontroller?" and "StampWorks" tutorials in Parallax's Stamps in Class downloads area show examples of this.
www.opto22.com/site/pr_cat_sc.aspx?qs=100310071003
Post Edited (originator) : 3/18/2007 9:42:30 PM GMT
