Header pins — Parallax Forums
Header pins
RsadeikaRsadeika Posts: 3,901
edited 2007-03-17 21:46 in General Discussion
I am trying to find a source for some breadboard header pins, I have seen plenty of header pins, but nothing that I could use on a breadboard. The standard header pins, one side is short, meant for soldering to a pcb, but does not work out well for the breadboard. I tried googling, but nothing comes up.
  • Robert KubichekRobert Kubichek Posts: 343
    edited 2007-03-17 21:13
    Just look for longer pins, and then slide the plastic down a tad to be able to insert onto a breadboard...
    I have done it this way and works slick.
    Bob
    Look around at www.digikey.com
    "SIP header" or "SIP strip"
    There are assorted dimensions and configurations (pin lengths, right angle, etc.)
    Update -- The more pins on a strip, the harder it is to push into a breadboard.· The pins are better anchored in the strip in some than others.
    Post Edited (PJ Allen) : 3/17/2007 9:59:36 PM GMT
