EXCEL to EEPROM
I am working on a project where i have to load eeprom with data stored in excel sheet. I have an eeprom programmer to load the eeprom. But i am know sure how to generate a file formet compatible with the eeprom . i would appreciate if there is any help from any one .
thanks
sid
thanks
sid
Can you show us a small example of what the excel data looks like, and how you want it stored in the eeprom ?
Bean.
"A problem well defined is a problem half solved"
"Just because you're approved, doesn't mean you can afford it."
Coming soon! Propeller based OSD module www.hittconsulting.com
thanks for the reply,the matrix looks like this(just an example) below. The data on the excel sheet have to be put in the eeprom in some order like a1 - 0000H, A2- 0001H, A3- 0002H like wise.
thanks,
sid
I am not able to upload the spreadsheet anyway...
a b c d e
1 1 2 3 1 2
2 1 2 3 1 2
3 1 2 3 1 2
4 1 2 3 1 2
5 1 2 3 1 2
this example looks similar to what i have ....a,b,c,d,e and the 1,2,3,4,5 are taken to be similar to how data looks in a excel sheet.
I think intelhex is common.
Bean.
