basic stamp with motormind b
do i need to program basic stamp to to use motormind or can I just program motormind?
can anybody give me a code that woud work for both of these? all I want is a dc motor to run at 1440 rpms real time
Page 9 of the documentation (linked below) shows the connections and commands for Tachometer Measurements. So your motor will need a tach feeding back into the TACH_IN pin on the MMBe. As for code someone may have some similar code you can build off, but chances are you will have to write some code specifically for your setup since some of the commands sent will be dependant on the speed you want, the PWM frequency and the encoder feedback. Oh, and yes you will need a microcontroller. The MMBe cannot be programmed to run stand-alone. I hope this helps. Take care.
http://www.parallax.com/dl/docs/prod/datast/MotorMindB.pdf
http://www.solutions-cubed.com/solutions%20cubed/MMB2003.htm
