something wrong with my basic stap and BOE
Hello
I am joe.
something wrong with my basic stap and BOE.
when i disattached the serial cable, the BOE can't work.
When i connect the serial cable, it works.
any idea???
Post Edited By Moderator (Chris Savage (Parallax)) : 3/15/2007 7:16:16 PM GMT
I am joe.
any idea???
Can you give a more detailed description ..
Quattro
'Necessity is the mother of invention'
I am using the power supply it's writen here 9 v for BOE.
i have use 7 segment LED it's working but for my motor can't work...
if i connect the cable the motor is moving.
the led in SSC is on also...
thanks for replying
sorry what is RS-232 lines?
i didn't use any battery yet
all using DC power supply where i can change the voltage...
thanks for replying
RS-232 is the serial cable.
You write that you use a 7-segment LED. I'm a bit confused. What is that used for ?
Please can you reply on the question about the status of the GREEN LED when the serial cable is NOT connected ? Is it On of Off ?
