Iam trying to read the time of the gps "Garmin 12", to my pc through SX. I wrote the following program, but with no results. Please, can any body help me to do the task?
If you are using a 50MHz resonator I think you'll need to use OSCHS2 on the device line instead of OSCXT2.
Is the PC expecting just 3 binary bytes ? What software are you using to receive on the PC ?
Bean.
"A problem well defined is a problem half solved"
"Just because you're approved, doesn't mean you can afford it."
Coming soon! Propeller based OSD module www.hittconsulting.com ·
When I used this, not the time that will be displayed on the monitor, but another things.
Iam also using: max 232 between the SX and the gps and pc
Is this is a time problem?
Bean.
Just receive it and resend it.
Try this...
Bean.
Bean.
