Erratic Stepper
Hello Folks,
I am running 2 steppers with the BS2.
Pulse and direction to each using 4 pins on the stamp.
1·common power supply, only 1 motor runs at a time.
All runs well, the problem occurs when I turn the power off to the stamp and leave the power supply on to the drivers.
One motor holds position steady as a rock, the other one, after a few seconds, buzzes and chatters wildly, then calms down for a few seconds, then goes again. I have to kill the power to everything before it passes its limits and crashes.
The drivers are different brands but basically the same. They have internal pull-up/dn resistors.
Any clues ???
Any clues ???
It's likely that there's something not right about the internal pull-up/down resistors in that the Stamp is off, yet one motor seems to be affected by noise and the other is not.
