transistor selection
I am looking to use a transistor to control a 12 volt 1 Amp load. I have am using a Board of Education with a BS2 stamp for the control leg of the transistor. Does someone with more experience than myself have any suggestions of an easily located (Radio Shack or similar) transistor I could use?
Is there a web site to help is this type of selection?
thanks for the help
Magic Smoke Theory of Electronics –
Inside every electronic part there is magic smoke.
The magic smoke is what makes everything work.
If you release the magic smoke, the part stops working!
thanks for the help
I'd suggest connecting a resistor between the gate and ground to keep the IRF510 turned off until your program does a HIGH. Any value from 10K to 100K should work.
In terms of selection: You want a device with a high enough voltage rating (probably 2-3 times that of the circuit involved) and a high enough current rating (consider that many loads have a peak current and an average current ... the transistor should be rated for the peak current). Any switch has some resistance including transistors. You're generally interested in the saturation voltage drop or the "on" voltage drop. That times the peak current gives the peak power that the switch has to dissipate. The IRF510 has an "on" resistance of about 0.5 ohms. At 1 amp, that's a 0.5V drop which comes out to 1/2 watt dissipation. You may want a small heatsink if the load is going to be on for long periods of time.
Post Edited (Mike Green) : 3/14/2007 3:20:07 PM GMT
I really have no experience with the MOSFET, but will gladly buy the IRF510 and have a go at it.
I will not be closing the switch for that long of a time. I have a bot I am building that will drive around a CAD classroom and "shoot" kids with Starburst candies. This will be used to control a solenoid to fire a pneumatic piston.
Another option would be to use a conventional NPN power transistor like the TIP3055 from RS (www.radioshack.com/product/index.jsp?parentPage=family&summary=summary&techSpecs=techSpecs¤tTab=summary&cp=2032058.2032230.2032279&custRatings=custRatings&features=features&accessories=accessories&productId=2062611&support=support&tab=techSpecs). This can also handle the voltage and current involved and would need about 20ma of base current. You would a 220 ohm series resistor in the base lead (to the Stamp).
With a short duty cycle (firing a pneumatic piston), you should not need a heatsink.
I posted a sample schematic and PDF of a 'pvdz172n' in the following thread
http://forums.parallax.com/showthread.php?p=632696
this has the following advantages -
1. Electrical isolation - as it is optically coupled
2. Capable of driving up to 1.5amps
3. 60v DC capable
4. Integrated reverse biased diode for protection when using inductive loads..
5. Uses a MOSFET switching stage.
Quattro
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 3/16/2007 7:32:53 PM GMT
Re IR HEXFET PVDZ172N unit you suggested..
Have you used these on high speed solenoids ?? MAC valve approx 170mA at 24VDC
I looked at the spec sheet and a little surprised about the 2mS response ..
that seems a little slow ..
Ronald Nollet Australia
I specifically use these for standard operations i.e. DC motor drives or pneumatic solenoid switching where time is not critical.
As you are aware - mission critical or time sensitive operations do not lend themselves well to opto isolation due to the inherent time delays.
These are ideal for the task outlined here .
I would be interested in your feedback if you were to try this device on a few applications..I have used them for years and have yet to have a failure..
Quattro
Is there a resource to help in the selection of solid-state switches? I am looking for a web page or a book where I can select options like current, power consumption, ect and have a few suggestions of switched to use.
