Hydra or Propeller starter kit...
I pretty much made up my mind of getting the Hydra kit over the Propeller starter kit.
75% in favor of the Hydra, so it should not be to hard to convince me the last 25%...
What I like about the Prop kit is the breadboard for the through hole components.
Is it possible to do some kind of cable to connect to a breadboard with the Experimenter card that comes with the kit ?
I'm giving it a week, if I still want the Hydra next week, I'll order it on Wednesday...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Experience level:
/Bamse
By the way, when you make your cable, use some kind of header pins to connect the cable to the breadboard. They're much better mechanically than just using tinned wire.
Andre'
The added bonus with the Hydra compared to the Propeller starter kit is that it's focused around game development.
I'm going to check out the XGameStation website and read up a little bit more before I order the kit...
Thanks guys...
Experience level:
/Bamse
Andre'
I really like the speech capabilities...
http://forums.parallax.com/forums/default.aspx?f=25&p=1&m=152683
Anyhow, I've got an extra bonus which means I'll order the Hydra tomorrow...
Experience level:
/Bamse
Just one quick question...
The kit seem to come with everything you need and for what I want to do I don't see anything missing...
Is there anything you guys wish you had ordered with the kit once you got it and had it for a week?
Any extra crystals, LED displays, flux capacitors, star shrinkers or anything like that ?
Experience level:
/Bamse
A nice wall-hung flat-screen TV with a built-in mini-bar and juicer. You'll need some kind of video display and you'll find it hard to drag yourself away from it all for a while. You might as well plan for the siege.
Andre'
Unfortunately I could not find the mini-bar and juicer on the Parallax WebSite so I guess I have to do without them.
Luckily for me I got a fridge with cold soda and beer within reach though...
I have a 15" CRT TV that I plan to use and in case I want to try out the VGA I got the 15" LCD monitor.
Thanks guys...
Experience level:
/Bamse
Andre'
Just got the E-mail that it has been shipped...
Now I have to bookmark the UPS site and check it every 10 minutes for progress...
Experience level:
/Bamse
Andre'
Back to Bamse, I bought a bunch of SX chips and breadboards and have been programming them in assembly. I've also got a BOE-Bot. I was planning on buying the Propeller Education Kit to build a PEK-Bot. There's also a nice set of educational material that Andy Lindsay is writing for the PEK. It seemed like it might be a more comprehensive experience than with the Hydra. let me know your thoughts. I will probably buy the Hydra anyway at some point, so it's more a matter of sequence. I'm not that much of a gamer, so the games aren't a huge attraction for me. It's more about learning about electronics, circuits and the propeller.
One manufacturer I've seen is Tern (www.tern.com).
Andre'
So far I'm on page 560 of 800 and it's been focusing on graphics most of the time.
However this is really what I want and it reminds me of the programming I used to do on my Commodore 64 20 years ago...
And with the upcoming Xtreme 512K SRAM card, it is going to be really cool to play with the Hydra...
And as Andre' said, you can hook up components to the Experimenters card or just get the connections from it and use a breadboard...
Think of all cool input devices you could hook up to use in games...
Experience level:
/Bamse
