Audio Input with the Unidirectional Condenser Microphone Element: PLEASE HELP!
Would the Unidirectional Condenser Microphone Element from Radio Shack be suitable for use as an audio input?
-Thank You,
Jeffrey
-Thank You,
Jeffrey
I am using the Unidirectional Condenser Microphone element in place of the audio input on the diagram. A description of the product can be found at www.radioshack.com/product/index.jsp?productId=2103751&cp=&sr=1&origkw=Unidirectional+Microphone+Element&kw=unidirectional+microphone+element&parentPage=search
(just type in Unidirectional Condenser Microphone element in the search bar of the radioshack home page)
I'm not sure if this helps but I'm using the microphone+schmitt trigger & some programming w/ pbasic in order to measure frequency of sound from a violin.
I've used these in arrays to get a better signal-to-noise ratio. If you get good ones they are pretty decent microphones.
Bean.
Coming soon! Propeller based OSD module www.hittconsulting.com
