propellar guitar amp?
samsn4
I'm new to the prop,less than a year expirence, and was wondering if i could build an amplifer based on the prop with a touch screen interface?
There are a number of people in a thread in the "Sandbox" forum working on an amplifier with digital controls. I believe it's a high end sound system.
For controlling the amplifier i was thinking about using the prop for the amp. Input the signal from the guitar and sample it then figure out how to setup an equilizer and maybe some effects. It's just an idea, but maybe i make something happen
Thanks for any and all input Guys
Daniel Mueth
Daniel Mueth
I was thinking along the same lines.
It appears that a better quality A/D conversion (seperate chip) would have to be used as the Props internal capabilities can't do a high enough bit resolution/sample rate. I may be wrong on this. It may be possible to use more than one cog to get better quality.
It has been pointed out that the Prop is not a DSP, but it may be able to handle realtime effects. I know very little about audio processing. I'm just starting to research it.
I stand on the shoulders of giants
I was thinking in that ideas last times, I believe that make fuzz effects could be great with the PChip, I would like a reverb unit too !! but all I know about reverb needs a bit of float point matematics, and I don't believe that could be done. Floating points rutines are still a bit slow for that....
Some years ago I've done some reverb, echo and octaver effect with the SX, it works very well, but not professional quality.
Here's a link to read about my project...perhaps you could get some another idea from them. Look for the SX code inside.
http://www.sxlist.com/techref/ubicom/contest/reverb/index.htm?key=Geraci&from=%2Ftechref%2Fscenix%2Findex%2Ehtm
Regards.
Alberto.
