Using P30 & P31 as Outputs after bootup
Is there any special precautions I need to take when using P30 & P31 as outputs after bootup? What happens when the pins are configured as outputs and a PropPlug or propchip is connected? Would series resistors be advisable?
Tom
Tom
What happens when you are reprogramming the chip, will the coms chatter cause a problem with your loads? (robot motor enages forward and reverse together!) Unless the load is fairly dumb like an indicator or perhaps even a data line that requires other lines to be asserted anyway (SPI) it is usually better to leave those lines for programming and debugging. But that being said, I have used those pins for other things too, I just made supersure that there was no conflict. If I had to ask someone else then I shouldn't do it.
*Peter*
Tom
