playstation controller sx helper
I'm trying to build a playstation controller interface according the the nuts & volts article: www.parallax.com/dl/docs/cols/nv/vol7/col/NV129.pdf
I have built up and programed the sx chip from the articles code, but cant seem to get it to work with my propellar. the only thing I changed in the sx code was setting the serial IO pin that goes to the propellar to cmos level and put a 1k resistor in series with the props pin. Am I missing something, is there anything else that would need to be done in order to interface the sx and prop?
i'm using full duplex serial (15,15,%1100,38400) to talk to the sx chip. Is it ok to use the same pin for TX and RX with full duplex serial? or do I need to use a one wire serial object?
the sx chip is programed to talk to the basic stamp so the serial line is inverted. Is %1100 a corect setting for full duplex serial?
I would try to write my own program in SXB to talk directly to the propellar with both TX and RX pins if I knew anything about programing SX chips (maybe in the future) so for now i'm stuck using the code from the article.
has anyone built this interface and maybe has a spin test program for it?
thanks
Owen
thanks
Owen
Parallax Forums - If you're ready to learn, we're ready to help.
Post Edited (CJ) : 3/11/2007 6:58:00 PM GMT
thanks
Owen
the connection diagram is included in the object.
please note that the pins are based on the console side connector the controller plugs into
www.lynxmotion.com/Product.aspx?productID=73&CategoryID=
These is also some protocol information to be found there, but not as complete as the nuts and volts article.
I guess I don't need to bother to design one now anymore
Mahjongg
p.s. The tread I was talking about is the " HYDRA SRAM CARD COMMING SOON..." thread.
Post Edited (mahjongg) : 3/11/2007 11:46:54 PM GMT
it's working great for me and I think it would be a good addition to the object exchange
Owen
Stan Dobrowski
if it works, please let me know so I can list it as a tested model
