Propeller Support board
We have a new board called the Propeller Support board.· This is a small platform, .800 x 2.100, which plugs into a breadboard or into an existing 40-pin DIP socket.· The bottom of the platform has a 20pf 5mHz SMD crystal and a 24LC512 SMD EEPROM with 10K pullups, all·soldered in place.· EEPROM is connected to Pins 28 and 29.· The user connects Vss to either of the Prop's Vss pins and 3.3VDC to both Vdd pins.· Add programming connections and you have a ready-to-go Propeller.
I have attached the layout.· You will need Expresspcb to view it.· Remember you are looking at the BOTTOM of the board.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
