FullDuplex Serial Documentation ? — Parallax Forums
octopusoctopus Posts: 3
edited 2007-03-11 14:06 in Propeller 1
After downloading Martin Hebel's "Extended_FDSerial.spin" from the Object Exchange I noticed his comment lines saying: "·See FullDuplex Serial Documentation", but I have no idea where to find this documentation.
So·anyone·leading me to the original documentation belonging to "FullDuplexSerial.spin" does me a great favor.
Thank you in advance
Paul
  • T ChapT Chap Posts: 4,260
    edited 2007-03-11 13:26
    You will notice in the Extended version there is the referenced OBJ to the original "Full Duplex Object", which means that Martins extended version actually uses parts of the original.
    For each method there are some notes in the original located under each method that give some info on usage, rather than copy and paste, Martin suggests just looking back at the original under each method for the notes.
  • octopusoctopus Posts: 3
    thanks originator,
    you're right about the comments in the original spin code, I did hope for a bit more elaborate doc ...
