Running 12V Micropump w/ BS2????
This is my first post so I will explain what myself and my senior design project is. My name is Jason Palmer and I am a senior in Biological Engineering. I am building a Dual BioSensor for the detection of E. coli in water. Various chemicals will be used to react with the E. coli which will cause an oxygen reaction. The amount of oxygen released will be detected by a dissolved oxygen sensor that is separate from the BS2. I will also be detecting a change in color of the chemicals via light absorption with a TSL120 light sensor and a 420nm LED.
I am using four 150SP micropumps from BioChem Valve. They run on 12V DC with 2.6 watts of power. The spec sheet can be found here. A 12V rechargeable will be used as a power source. I am using TIP120 transistors for each pump.
Currently I am in the building phase and I am using a BS2 Homework board to test everything out (ease of use with breadboard). For the final setup I plan to use a BS2 Super Carrier Board so that I can solder all of the connections.
Now to my questions.
1) For the TIP120 the base will be connected to the BS2 output with a 1K resistor in between. For the collector, does the ground hook up to the negative terminal of the battery or to the ground of the BS2? I will connect all the pumps to a single ground wire.
2) How do I wire the emitter into the with the + terminal of the battery and the BS2? What do I do with the second wire of the micropump?
3) I want to use a the 12V battery to power the pumps and the BS2 Super Carrier Board. Can I just wire the power line into the board since it already has a voltage regulator or do I need to add a resistor or capacitor? Would it be easier to just use a 9V battery that plugs into the board to power it instead of the 12V?
4) Is there anything in the wiring that I have overlooked that is needed or would help the system perform better? Any suggestions for the other components?
Sorry if this is a bunch of stuff. This is the first time I have fooled with a BS2 and I do not know much about electrical components, so I am learning on the fly.
THANKS FOR THE HELP.
Actually for each TIP120 the emitter will go to ground. The negative side of the motor will go to the collector. The positive side of the motor will go to the common power supply for the motors which should probably be different from the BASIC Stamp supply depending on its specs. The NPN transistor should be switching the negative side of each motor. I hope this helps. Take care.
2) The emmiter goes to the motor - then the motor + goes to the battery +
3) 12v dc should be OK for the stamp, it will only use what it needs. 5-15V is OK.
4) attach the schematic and maybe we could tell you.
- Stephen
- Stephen
Is this correct?
Sorry for the novice questions..........
Tracy Allen
www.emesystems.com
