ADC 0809 interfacing with BS2
Hi
··· i need to interface the ADC 0809 with BS2 and list the sample data on the debug screen.im in doubt with the connection between the digital outputs(D0-D7) with the BS2 whether i can directly connect a wire between· the digital out pins and the BS2 pin or use a pulldown resistor for each of the pin.In the datasheet it is specified that the outputs are TTL Tristate compatible so im little confused.
The datasheet can be seen here >> http://www.ortodoxism.ro/datasheets/nationalsemiconductor/DS005672.PDF
Thank you for your help in advance.
Jeff T.
Jeff T.
1.First enable the Address Latch Enable(ALE) with a short pulse of duration approximately for 1 clock period.
2.A 3 bit address corresponding to the specific analog input pin we want to use is given to the A,B,C terminals .
3.After a very short time give the start pulse.
4.After convertion the EOC pin indicates it with a high state.it is given to the stamp so that it can give the next start pulse for the forthcoming data.
5.All the 8 digital out pins are connected to the stamp without any resistors and the BS2 displays the digital data on the debug window.
6.output enable is pin is made high to get the output dig. data.
Note:Im planning to use a 555 timer in astable mode for the clock input.
Im going to test with an audio output as the analog signal.The sampling rate would come around 2 x ( max frequency of audio signal i.e 20 KHz) = 40 KHz which is the clock input.
Jeff T.
