No connector pins for ATN
How does the programming handshake work?· I am developing a product that does not have enough connector pins for the ATN line.· I would like the ability to reprogram the controller in the rare event an update is required.· Is there a method I can use to reprogram the BS2-IC using a push button on the board or something?· The device will be soldered in and in fact, the entire circuit will be encapsulated.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Thanks for the idea about the 4-pin header. This would be an inexpensive solution for a parallel connector to the main connector for the purpose of programming. I could even eliminate the two capacitors on the ATN line using this method--my main connector to the outside world is small and only has 4 pins, one of which will be to power the device.
Dale
