Needs help on COMPARE command
Hello there, I have the BS2 & BS2px boards, I need to make a diesel level detector(for·trailer tank), I think don't need a RC circuit cause the tank output is energized, it uses a 240 ohm potentiometer, I need to read the voltage output and tried with BS2px but only read with one comparator, I have tried to activate the other ports like comparators and no success and only 5V like maximum to compare(maximum voltage output=8VDC, minimum is 3VDC), any help welcome, thanks in advance.
Adriana R.
Adriana R.
