7 segment displays
Hello,
If I wanted to use seven segment displays to display static numbers (non changing) can I just tie all the necessary pins together to ground and the common anode to positive 3 volts. I know this will light but I am wondering if 3 volts is too much current for the displays (most are red and I know I usually power red leds with less than 3 volts). I am having a hard time finding some data sheets. I am also wondering if it is ok to wire these thing up in parallel like this, I usually wire led in series but there is no way to do this with a common anode. Basically I am just wondering what the best way is to wire up 7 segment displays for displaying static numbers???
rr
rr
You've got to use current-limiting resistors: one for each segment that gets lit. And this will only work for a group of single-digit displays. Displays with multiple digits in one housing have to be time-multiplexed.
- Rick
i need to wire up about three hundred of these displays and resistors add a lot of work. what if i regulate my voltage to·2 volts·using some thing like this.
http://focus.ti.com/lit/ds/symlink/pt6461.pdf
i know that i really need to get my multimeter out and make some mesurements. but i just want to make sure that as long as give the displays 2 volts i dont need resistors. i guess i could give them even less if i need (1.8 volts or something)...
do think it is·safe to think that as long as each segment sees less than 20 ma i am ok???
It is possible to cheat a little by using a single resistor on the common pin, but you must calculate it's value based off of each display and the number of segments lit, and if you use really cheap displays, the variation in Vf (the voltage drop across the resistor when illuminated at target current) can cause some segments to become the main conduits of current in the display causing one or more segments to burn more brightly than other segments.
You are best served by purchasing SIP bus resistors, these are a series of·resistors whose one end are all tied together, and the other end you tie to each segment you illuminate. They take very little space and are easy to incoporate and wire into a design.
Paul Baker
