Quick Question
Alright, I just made a program with the BS2 module. The program is written for the BS2. I am using is for navigation, and am almost done for those people who read my last topic, and helped me out with it
. I am using the Parallax QTI's in conjunction with the parallax RFID tags, and reader. It just so happens that I am almost out of memory and was looking into buying the BS2sx module since it can process faster and has a lot more memory. Now the one question I have is, will my program written in the BS2 language work with the BS2sx? Or will i have to re-write the code with the BS2sx's codes. Are the codes the same except they just have more capabilities? Or will it work out perfect and i won't have to change a thing in my program?
Any help would be useful.
Thanks in advance,
-Element
Thanks in advance,
-Element
If you're almost out of memory, you have to understand that the larger memory Stamps still have the same 2K limitation for the memory of a program "slot". The difference is that a program may have more than one slot on the larger Stamps. This works a bit like overlays in that two slots can share variables (again consult the PBasic manual for the RUN statement), but it's not like you can call a routine in the "overlay". You can RUN a "slot" from the beginning and can only return to another slot by doing a RUN which again executes the slot from the beginning.
Frequently, programs can be made much smaller by making subroutines where appropriate, by simplifying code, by making use of tables in EEPROM.
