GSM Module
william chan
When is Parallax going to sell a small, low cost GSM module with SIM card holder to complete it's product range?
Is it coming soon?
www.fd.com.my
www.mercedes.com.my
Is it coming soon?
www.fd.com.my
www.mercedes.com.my
Paul Baker
Preferably the module should be as simple as possible, just a 0-5v serial interface will do.
5 pins, 5V, Gnd, Tx, Rx and Sleep will be beautiful.
The lower the current consumption, the better.
Would you like us to help you test them with the SX?
www.fd.com.my
www.mercedes.com.my
GSM now covers 850/900/1800/1900MHz...
To see which countries uses which frequencies, check out http://www.gsmworld.com
(It's also quite handy to see which networks have roaming agreements and what kind of services you can expect.)
Don't visit my new website...
Paul Baker
Paul Baker
I was also hoping for a simpler SMS only module.
Maybe you could make one by not connecting all the voice and mic pins, only the serial interface.
Built in antennas will be beautiful.
www.fd.com.my
www.mercedes.com.my
Paul Baker
You might want to take a look at enfora.
Unless you plan on going into production, opt for a prepackaged modem like their GSM1218, which in small quantities doesn't cost much more than the OEM card modules. Plug and play. The OEM card modules are quite a hassle, to supply the power and so on, and those Molex connectors are a horror to solder on a board.
Tracy Allen
www.emesystems.com
Their overall size is 40 x 33 mm and 50 x 33 mm respectively.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 3/10/2007 1:35:13 AM GMT
Quad band GSM/GPRS radio that supports Voice/SMS/CSD, has an internal IP stack that supports UDP/TCP to serial·connections, and has a maximum transmit output on 850/900 of 2 watts, 1800/1900 of 1 watt.
In a 28mm x 27mm x 2.4mm package.
Post Edited (Mike Cook) : 3/10/2007 11:53:02 AM GMT
We need the GSM modules to be more hobbyist friendly.
What Parallax did with PING))) is a very good idea.
You can do the same thing by adding an additional board that holds the OEM GSM module.
Add a SX processor, a simple SIM card holder and a small ceramic antenna and also a small mic.
Then provide only 5 or 6 pins on a standard header.
Thanks a million.
www.fd.com.my
www.mercedes.com.my
It would be great if Parallax create some product based on GSM comunication.
There are lots of GSM modem modules already available, and some of that with SIM card holder built-in.
For now i'll be looking in the forums if anyone project something.
See ya!
Sergio Tavares
