Misprint?
I'm wondering if there're some misprints in the text: Applying the Boe-Bot Digital Encoder
P.9: (see attached file) the forth expression
My calculation's not the same as the text.
P.10:
When Left Wheel moves first, why does the new angle in the L VECTOR become (theta + delta)?
Shouldn't it be (theta - delta) according to the angles defined on P.8 ?
Thanks~
Post Edited (koolitude) : 3/6/2007 4:06:23 AM GMT
P.10:
Thanks~
You're right: there's an error in the formula for y1R, for which you have provided the correct expression. Fortunately, this appears to be no more than a typo, in that using your expression in the solution of y1R below, yields the expression given in the text. (Phew!)
I'll make the necessary change and submit the corrected manuscript to Parallax.
Thanks much for catching this and bringing it to my attension!
You're welcome...
I wanna understand the theory behind rather than just using the program you wrote straight away... That's why I am trying to read the text again and again; and I found that...
By the way, if you know the answer for the L VECTOR, could you please let me know as well
Thank you very much!
koolitude.
Post Edited (koolitude) : 3/7/2007 1:53:39 AM GMT
