EVA My little friend goes to school.
I've been wondering around some of the Robots forums on the web lately just to see what the autonomus guys build. It's funny how most of them have a huge rats nest of wiring in their projects. This is sorta understandable since it takes a lot of wires to talk to even a simple PIC computer and let it control even a simple machine. Anyways I finally got around to modifying EVA to give her a little of both schools of robotic control. EVA is now both Autonomus and a ROV at the flick of a switch on my transmitter. Right now she a little blind since·I don't have her eyeballs intalled but she has 4 switches to tell her little brain·when she runs into things. I call this the Bump and Go mode. One of the problems that·I had to solve was·is the typical wanting a PIC computer to do more than one thing at a time. ·I already knew that yes a Basic Stamp2 can read the signal from a Receiver and yes it can talk to a speed controller. But when you want it to read several receiver channels and keep sending pulses to the speed controllers the computer starts to get loaded up and the motion gets really Jerky. So in this version·I added a servo control board to take the load off of the BASIC stamp2 and now the motion is nice and smooth. ·And by golly it actually works. So at this point I've created my own Rats nest of wiring. It's almost too simple this Tele-Autonomus stuff.
Eva with her little claw and wireless camera and mount for the Tele-operated mode. In teleoperated mode she can actually open the refrigerator door and grab a can
Eva and the latest Rats nest of wires. I need to do a bit of clean up now that she's working in both modes
Eva video doing the refrigerator run in First Person·tele-operated mode I drive her by watching the video feed on a television. Hopefully someday I can teach her how to do this by herself.
http://www.youtube.com/watch?v=_X5_R0a10Bg
Steven Kirk Nelson (slamer)
Team K.I.S.S
Build Safe, Build Mean, Build Strong!
Post Edited (slamer) : 3/6/2007 3:26:46 AM GMT
Team K.I.S.S
··' {$STAMP BS2}
······· '{$PBASIC 2.5}
'radio or autonomus control with the Basic Stamp 2 using the serial servo control board
'Variables
ch VAR Byte
ch1 VAR Byte
ch2 VAR Byte
ch3 VAR Byte
pw VAR Word
pw1 VAR Word
pw2 VAR Word
pw3 VAR Word
x VAR Byte
ra VAR Byte 'servo seek rate
'switch Variables
leftfront VAR Bit
rightfront VAR Bit
leftrear VAR Bit
rightrear VAR Bit
dipswitch1 VAR Bit
Sdat CON 15·· 'serial communication channel pin 15 from stamp to servo control board
baud CON 396· 'baud rate
ra = 7· 'servo control board servo seek position rate
ch = 0 'servo control board output pin
ch1 = 1· 'servo control board output pin
x=0
·channel0 VAR Word
·channel1 VAR Word
·channel2 VAR Word
·channel3 VAR Word
·channel4 VAR Word
·'This program READs multiple 75 Mhz radio reciever servo output channels.
· 'by scanning the Pulse Width Modulation OUTPUT frequency of each channel
' Aproxamately a pulsewidth reading of 750 is stick centered on transmitter
' test for tranmitter stick movement from center position then jump to subroutines to move servos and robot
·· 'Test· 4 Receiver channel outputs with the Pulsin command by reading servo signal line
'·· Receiver outputs connected to pin zero through pin 3 on the Board of Education
'Use (1) FOR logic HIGH OR (0) FOR logic LOW in pulsin command trigger threshold
Receiver:
·· 'Read the signals from the receiver and sends the values to the servo control board
·· 'the signals from the servo control board is then sent to the speed controllers.
·· 'Standard Teleoperated mode unless channel2 variable changes
DO
··· PULSIN 0,1,channel0 'Measure receiver positive pulse pin p0
··· PULSIN 1,1,channel1 'Measure receiver positive pulse pin p1
··· PULSIN 2,1,channel2 'Measure receiver positive pulse pin p2
·· 'PULSIN 3,1,channel3 'Measure receiver positive pulse pin p3····· 'future use
·' check receiver to activate autonomus mode actually channel 5 on receiver
·IF channel2· > 1000· THEN AutoEVA
·· pw = channel1
·· pw1 = channel0
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch1, ra, pw1.LOWBYTE, pw1.HIGHBYTE, CR]
LOOP
'Drive motor controls
motorstop:
pw=781
pw1= 784
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch1, ra, pw1.LOWBYTE, pw1.HIGHBYTE, CR ]
RETURN
END
Forward:
·x=0
DO
pw=850
pw1=450
x=x+1
LOOP UNTIL x=30
IF x=30 THEN GOSUB motorstop
·RETURN
Backward:
·x=0
DO
pw=450
pw1=850
x=x+1
LOOP UNTIL x=30
IF x =30 THEN GOSUB motorstop
·RETURN
Turnright:
x=0
DO
pw=850
pw1=850
x=x+1
LOOP UNTIL x=30
·RETURN
Turnleft:
·x=0
DO
pw=450
pw1=450
x=x+1
LOOP UNTIL x=30
·RETURN
AutoEVA:
GOSUB motorstop
'PAUSE 10000
DO
'checkswitchs bump and go mode
checkswitch:
PULSIN 2,1,channel2 'Measure receiver positive pulse pin· 2
IF channel2· < 1000· THEN Receiver· 'check for RC control mode
'get EVA moving until she bumps into something
pw=1050 'set speed
pw1=650 'set speed
'enable bump switches
rightfront = IN4
rightrear = IN5
leftfront = IN6
leftrear = IN7
dipswitch1 = IN11························· 'future use
·'test for collisions
·IF (leftfront = 0) AND (rightfront = 0) THEN ' Both front switches detect obstacle
GOSUB Backward ' Back up & U-turn (left twice)
GOSUB Turnleft
GOSUB Turnleft
ELSEIF (leftfront = 0) THEN ' Left front switch contacts
GOSUB Backward ' Back up & turn right
GOSUB Turnright
ELSEIF (rightfront = 0) THEN ' Right front switch contacts
GOSUB Backward ' Back up & turn left
GOSUB Turnleft
ELSEIF (leftrear = 0) THEN 'Left rear switch contact
GOSUB Forward
GOSUB Turnright
ELSEIF (rightrear = 0) THEN 'Right rear switch contacts
GOSUB Forward
GOSUB Turnleft
ENDIF
LOOP
RETURN
Team K.I.S.S
Post Edited (slamer) : 3/7/2007 4:06:53 AM GMT
