Pins 28-31 - Special and General Purpose - need clarification
I need some clarification (probably a dumb ?n) on the following special pins below:
The manual says that these special purpose upon boot/power up/reset and there after they are general pupose.
·P28 - I2C SCL connection to optional, external EEPROM.
·P29 - I2C SDA connection to optional, external EEPROM.
·P30 - Serial Tx to host.
·P31 - Serial Rx from host.
I'd like to use these pins as/for general purpose devices. From a wiring perspective how does one use these pins. Can the devices be connected just like other regular pins. Or, is there special guidance to hooking up devices to these pins.
I tried connecting DS1620 to these pins - however, I see a wierd behavior w/ the readings, so I ended up moving it to other pins.
thanks in advance
"any small object, accidentally dropped, goes and hides behind a larger object."
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
http://ALIBE.crosscity.com/
thanks in advance
You could use P30/31 as long as your device can tolerate the Propeller transmitting a little on P30 after reset and your device won't fiddle with P31 until the boot sequence is over. If you're using a permanently wired MAX232 or USB-serial adapter, P31 will be driven by the serial port and you may not be able to use it without some external logic to select a different signal.
a couple of more beginner's ?s:
1. What is a chip select. Is it a way by which we can control which device is electronically plugged into pins. Sort of like a "Video Input Selector" that we have in our home theatre Receivers? (that must be the most basic ?n of the year thus far)
2. do these pins go into Special purpose mode when calling ::Reboot() or only when power up/reset.
2. they are normal I/O pins, they just are used in the boot up/programming sequence
Parallax Forums - If you're ready to learn, we're ready to help.
For some chips, the data input and data output are never active at the same time and can be connected together. The
clock and data lines are inactive unless the chip select pin is low (or sometimes high - depends on the chip). Look at the
datasheet and examples on Parallax's webstore for the HM55B compass. It uses SPI.
2) Reboot is functionally the same as a reset/power up. These pins behave the same either way.
[noparse]:)[/noparse]
thanks for the explanation Mike, CJ.
