Snap-in Caps
Lightfoot
What is the proper way to mount those snap-in aluminum electrolytic capacitors?· Any pictures?
THanks
THanks
These type caps were usually big electrolytics used in power supply designs. The connector was mounted in the chassis and the caps twist-locked into them or snapped sideways into sort of a keyhole connector.
Unless you can find an old chassis with a suitable connector to rob, you're probably going to have to go the the can manufacturer.
Alternatively, you can probably solder a couple of pig-tails to the connectors; or, some cap connectors looked sort of like a nail-head and a 1/4" push on connector would slide right on.
Cheers
Tom Sisk
http://www.siskconsult.com
