Voltage Questions
I can't seem to find this information anywhere...· I know it must be available somewhere, but I can't manage to find it.·
1.· What is the max current that I can take from the Vdd on the BS Super Carrier Board?· I would like to run the BS2sx as well as a servo motor.· Is this possible?
2.· What is the maximum Vin for the BS2sx?· Does it have to be under 12V?
Thank you!!
Thank you!!
2) The maximum Vin for the BS2sx is set by the regulator on the substrate, an LT1121 which has a maximum input voltage of 30V. Again, the power dissipation may limit how much current you can draw. Not only the processor, but the I/O source current has to come from this regulator. If you have a lot of LEDs or a reed relay or two, this may limit the possible Vin.
·· The max VIN for the BS2sx Module is 12V before the regulator will shut down. Now, on the Super Carrier Board the BASIC Stamp Module will get its power from VDD, not VIN as on other boards, so input voltage will be determined by the LM2940 and total current draw (more accurately, power dissipation). Take care.
