BASIC Stamp 1 Serial Adapter and BS1 Module
Andrew_T
I have been using a BS2 for a project and it's working fine.
I decided to re-write the program using a BS1 Module, in preparation I was doing some simple programs to make sure the BS1 serial adapter was talking to the BS1 module (using BS Editor 2.2.6).
When I run the program from the editor, it is just scanning for the BS1 module then times out - BS1 module not found.
The serial port is working fine with the BS2 but not the BS1 module.
Is there any thing I can do to test the BS1 serial adapter or to check the BS1 module ?
Thanks.
Andrew.
Thanks.
Andrew.
I have the BS1 module plunged directly to the BS1 serial adapter socket (as shown in the BS1-IC Module schematic). Just in case there was a bad connection I have tried using jumper cables from the serial adapter socket to a beadbard were the BS1 module is located.
Now I'm assuming the BS1 module will get it's power from the serial adapter during programming ?
I don't think so. You'll need to supply your own power to the BS1 module according to www.parallax.com/html_pages/products/basicstamps/bs1.asp
