Spin Stamp Progress
Just wondering if anybody had any further info on the Spin Stamp?
I'm eager to see if any progress has been made on this as I would have loved to been an alpha/beta tester but I missed out as I·didn't become·a parallax customer until december.
The spin stamp would perfectly fit a project I am undertaking right now....
Any info would be appreciated.
Damo
Damo
Paul Baker
Paul Baker
thanks,
ACfishing
P.S. It is still programmed in spin also and requires a propclip
Paul Baker
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Paul Baker
I assume physical pins 1, 2 and 3 would not be connected.· Could you program it with a PropPlug?· What pins?·
Does it have RESn and BOEn pins?·
Does it need a crystal - what pins?
Sid
Don't have VGA?
Newzed@aol.com
Correct. PropClip on the edge (Divot side of DIP), they are hidden as well.
No
No
Remember its pin compatible with the Stamp, if the stamp doesn't have the pin, the Spin Stamp doesnt have the pin either.
Paul Baker
It's just like a BS2 except for the 3.3V I/O and the fact that you program it via a PropClip, not the serial port. The PropClip clamps on one end of the substrate. I imagine, if you were careful, you could solder a 4-pin header into the holes for the PropClip and use a PropPlug instead. It has the BS2 pin assignments and plugs directly into a BOE. The serial port works too, just not for programming (and the ATN pin is connected to one of the "other" Propeller I/O pins so you can monitor it).
I do not have a PropClip, only a PropPlug.· Is there a·picture available - I am concerned about the mechanics of the proposed piggyback.· Sorry to be so much trouble.
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Do you have any info on this Paul?
Paul Baker
