Gas pressure sensor
I have posted about making a tachometer for a school project but my teacher has asked for my class to consider using servos.
I was wondering if it would be possible to use a Gas pressure sensor with·a BS2 board. The idea that i had was to have a certain
amount of pressure that the sensor could allow until it would activate a servo that could open and close some type of valve in order to
release the pressure. Does parallax make a gas pressure sensor? i have been unable to find one on their website.·If anybody knows if this is possible
·please post your response. Thank you.
·········································· -Ron·
- Stephen
Also there are many ways to open or close a valve with a servo using gears from servo city.
thanks for your post.
-Ron
Look at my above post. It describes a water pressure sensor, but the sensor described could also be an air pressure sensor.
A servo is not powerful enough to hold a stopcock in position against gas pressure. However, a continuous rotation servo is strong enough to turn a screw that could release gas pressure.
Jameco electronics has some inexpensive pressure sending units (transducers). 0-5 psi etc. They can be put through an A/D converter and read with a basic stamp.
Depending on the valve, you can easily turn a small (low psi) valve with a servo. See edmund scientific for some small "low pressure" valves.
** Be very careful not to over pressure the vessel.** The larger the surface area, or vessel, the more dangerous it is and the less pressure you can use.
After that, you can use some simple IF/Then statements in your code to control the valve on/off or proportionally.
Good Luck!
http://www.parker.com/indexv4.asp
They deal with most of the HIGH pressure electric sensors and electric control·valves.
Team K.I.S.S
Build Safe, Build Mean, Build Strong!
