Intel 12VDC Fan(3wires) — Parallax Forums
ImranImran Posts: 20
edited 2007-03-04 21:49 in BASIC Stamp
Hi Guys,
Wanted to know, how to connect an Intel 12VDC Fan with a Professional Development Board.·It has got 3 wires(yellow, green, black).
Regards
  • ImranImran Posts: 20
    edited 2007-03-03 15:52
    hey guys, Just figured out, the black wire is Negative, Yellow is Positive, what is the Green wire for. Is it some kind of singal for hi or low....but how do I control the fan from a BS2. The high does not works, as it only gives out 3Volts to the fan, do I have to attach a transistor to it.
    edited 2007-03-03 19:27
    You will need to switch the fan with a transistor or mosfet controlled by the stamp and connected to 12v. (the mosfet/transistor, not the stamp) The other wire is a tach signal from the fan so the powering device can tell at what speed it is spinning. You could use this with the stamp.
    - Stephen
    edited 2007-03-04 05:47
    Hi Franklin,
    thanks for the info, I would quite appreicate if you could attach a schematic of it.
    http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv6.pdf
    - Stephen
