Spin PID?
I am researching which motors to use for a system, whether DC or AC brushless, then I'll get the drivers built and ready for code. Below 300 RPM with an encoder at 1000 counts per rev, would a crude PID be possible with Spin utilizing the rotary object? Has anyone already worked with the Propeller and PID for a closed loop servo system?
There are some excellent docs available doing simple PID with the Basic Stamps.
So simple crude PID would be walk in the park stuff... it really depends on what your trying to do.
300 RPM is relatively slow but would still generate 5000 pulses per second...the rotary object can handle that.
The counters in each COG can handle from what I understand 40MHZ..
There are some really neat simple closed loop servo systems out there with step and direction type signalling as well.
So you would not need to generate a analog signal..and the loop is closed inside the drive on some of these readily
available systems as well ...so all you need to generate is pulses ( and you have done that before)
Cheers
Ronald Nollet Australia
http://forums.parallax.com/showthread.php?p=635059
Post Edited (originator) : 3/2/2007 6:09:41 PM GMT
