OH NO, Broken pins
curious1
In an attempt to remove the BS2 from the BOE, (Lord that thing was IN THERE), all of the sudden one end came out much sooner than the other. Bent the pins, the 2 at the bottom, 8 and ? were bent almost 90 deg. I straightened all of the others but the 2 on the end broke off right where the pin begins to widen. Any suggestions on the best way to repair ? I may be able to do without the 2 I/O. I thought I might solder a jumper·to the broke pin and stick it in the breadboard. Will the stamp take the heat or should I leave it be ?
Open to suggestions,
Sadly
Sadly
Dave
Dave Andreae
Post Edited (Dave Andreae (Parallax)) : 3/2/2007 5:16:16 AM GMT
www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=112264
maybe you can just solder it into the IC Socket (on second thought )... just insert some scrap wire between the walls of the IC socket and the broken pin so the contact is made
www.maplin.co.uk/searchtemplate.asp?criteria=IC%20REMOVER
one of these lifts both sides at once, if you lift it straight up and slow.
... quickly, I could not find a U.S. supplier.
But you could make one if you are ambitious enough.
Drink Milk!
skype me: quispqix
echolink: 184783 KC0LGV
Regards
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
I may try that along with the socket to socket deal to preserve the connection.
