Telephone interface
I am trying to hook up a BS2 to a telephone- I want the phone to dial out based on commands given by the stamp. How does the circuit given in the manual's DTMFout command have to be modified? Do I need an entirely different circuit. Is there another device that would make this problem simpler?
Thanks for the help.
Post Edited (bddbbd.b) : 3/2/2007 2:25:13 AM GMT
As for making the problem simpler, get nearly any old modem and let the stamp tell the modem the number to dial.
It gives you an approved interface, some extra control lines like "Dial tone detected", etc and the stamp can easily interface with it on the serial port. Best of all, you can use almost any speed modem and many people will give you a box full of them for a few bucks. Ask around and try to stick with ones that use the Hayes "AT" command set.
Cheers,
Tom Sisk
http://www.siskconsult.com
For the stamp to dial, it does this:
1. Send the modem the number to dial.
2. Tell the modem to dial the number.
3. What happens at this point will depend a bit on what equipment you have just called.
Tom Sisk
Look at the nuts and volts column, Nuts & Volts Volume 1. nv19.zip
www.parallax.com/dl/docs/cols/nv/vol1/code/nv19.zip
the bs2 will dial but if I remember correctly, you need a higher xx2, (All I got are bs2's), for the answering part of the job.
check out nv60 too, but I forgot the volume that was in. also with the proper sequence you can program the bs2 to access your phone messages, (your own (don't make me wait records)) the phone messages are great for determining the pause duration.
And old telephones can be 'circuitry minimized' with the transformer and the proper switches. Also what I found that works the best is an older network block with pushbutton capability (DTMF) you then need 4 switches 2-on 2-off put on the relays you can get from the modems for the handset switches and you can toggle the relays from an output logic transistor driven or sent through an ls04 about 4 times, something to build up the current. but the network blocks are really something beautiful to own.
Also If you think you set up your block correctly and you get no dial-tone (or ring), just reverse the tip and ring wires for the correct polarity. (yes its ac with polarity) (even if that was correct)
Network blocks you can get at the thrift store. they are called telephones. but not that new shtuff, they are actually blocks, not circuit boards. AND REMEMBER how you un wired the block at the screw terminals because there is vertually nothing on the internet about them unless you do a really deep search.
probably because it is a network block it might be fcc approved, but don't quote me. I'll deny everything.
Hotline dialer,... www.vikingelectronics.com/products/view_product.php?pid=160
Not intended to advertise that product!
Drink Milk!
skype me: quispqix
echolink: 184783 KC0LGV
Post Edited (quispqix) : 3/3/2007 5:26:36 AM GMT
It's much better to use an old modem in that the modem has protective circuitry in it to protect against the ring voltage (maybe as high as 90VAC) and phone line transients (including from lightning). It will also keep you from getting into trouble if your phone suddenly stops working. Sure, you can hack something, but do investigate proper protective networks and build them in.
Drink Milk!
skype me: quispqix
Post Edited (quispqix) : 3/3/2007 1:36:07 PM GMT
So, to clarify what happens if I use a modem is that the stamp sends the number to the modem via serial communication, and tells it to dial through the serial output?... I never use the DTMFout instruction? and what would you estimate the learning curve on the modem is like? It sounds promising, since I know a lot more about programming than circuit design (though little enough of either...). Do you have any suggestions for finding documentation for modem wiring and modem programming?
Thanks for all the help, everyone.
Post Edited (bddbbd.b) : 3/3/2007 10:51:27 PM GMT
Drink Milk!
skype me: quispqix
Post Edited (quispqix) : 3/4/2007 3:05:53 AM GMT
