9V wall adapter
I realize that the 9V battery for the Propeller Education kit is probably not going to last me too long, so I am looking to go the way of a wall mount power adapter. Anything special I should look out for, or anything I need to do besides get the adapter and a connector for it? I was looking at these two parts from Jameco:
www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&pa=236937&productId=236937
www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=101178
Will these work?
Will these work?
how about this Package www.sparkfun.com/commerce/product_info.php?products_id=114 You'd need an appropriate wall wart to supply it, there's one that Sparkfun also sells, for less than that one you linked to at Jamaco.
This kit has a selectable output of 3.3V or 5V. You could run it at 5 volts and feed the 3.3V regulator that came with the PE kit.
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
