Full Duplex Serial Object Questions (again)
Ok....so I had to do a small add to my lower object file to get the send and receive going with it.....
Now I have a question....that I haven't seen the answer to.
Does the Full duplex object receive MSB or LSB?· (MSB most significant bit/LSB least significant bit)
I have a byte that I think will end up being backwards when I receive it. I can reverse order if it is.....but I would like to know what order the serial works.
James L
James L
Thanks ....it is funny....I never knew that. Hmmmm....I wonder how I got around that all this time. I guess this is the first time I have used asynchronous serial in any of my projects.
But I'll remember from now on.
James L
